ktmtragic Member K Join Date Jan 2013 Location Sydney Posts 92 Dec 4, 2014 #46 My understanding is Fire up RSLinx first then monitor with wireshark
Geospark Lifetime Supporting Member Join Date Feb 2012 Location Kildare Posts 3,010 Dec 4, 2014 #47 Aabeck said: ...Should the 5/05 have sent something out for Wireshark to see before RSLinx talked to it? Click to expand... Yes. You need to configure Wireshark to make a Gratuitous ARP request. Else it will not read anything from the SLC. Here is the configuration setup... 542126 - Obtaining IP address of a known device using Wireshark Access Level: Everyone Regards, George
Aabeck Member OP Join Date Feb 2013 Location Detroit Posts 1,860 Dec 4, 2014 #48 Geospark, Thanks that goes into detail more than I was familiar with.
a062549 Lifetime Supporting Member A Join Date Feb 2012 Location Home Posts 139 Dec 5, 2014 #49 Can you use the NETSH command to set the IP in a 5/05??
