SLC5/04 for DH+ connection
angi
Jan 2010
us
361
Hi guys
One question:
Could I connect my laptop with Slc5/04 using 1784-pcm5?(the 1784-pcm5 is for PLC5 from the AB manual on its website)
Hello,
Yes the PCM5 has an adapter on the end the should go on the end of the cable 1784-CP7 this is a 9 pin to round mini din... you also need a 1784-PCMK (A or B) that must match the cable
I have a little problem. I have a number of now classic SLC5/05's with which I am hoping to connect to Weidmuller ER20-FCB-EIP I/O nodes. I have...
1,843
I rarely come across machines at a customers shop with a SLC5/05 in it, however I have a new customer that has 2. I can connect through RSLinx...
48
14,895
Hi, I just borrow a SLC5/05 processor, I don't know its Ethernet port's IP address, and also unkown DF1 slave node and other parameters. How...
3,355
Dear all, Now,I've a PanelView 1000,and I want to connect it to SLC 5/05 through ETHERNET .After I finalized my tags and adjusted the connection...
3,661
Hi, I'm beginner in PLC's so my problem can be very simple :). I use Allan Bradley card 1784-KTX card for DH+ and RSLinx 2.43. Card is already...
5,270
