Hi.
We have several automation systems on a plant which runs on different PLC’s. We also have a topside network system that shows all the necessary information in a control room and for remote operations.
There are some other automation systems on the plant, and they want us to open up a connection to their network via OPC UA.
Do you know what the preferred way of doing this is? We use codesys complient PLC’s which support OPC directly. So in theory the customer could have direct connection to the PLC’s ethernet port and read/write data via OPC.
For security reasons I’m sceptical to this, so I was wondering if theres a better way to give access to the PLC data.
The PLC’s are already connected to a server on the plant, maybe we could set up an OPC server there and add some security for the connection. I’ve seen some python /c++ libraries for OPC server/clients and already tested some of the functionalities, but I wanted to check here if there are some well proven and safe ways of doing this.
