Control Logix 2 Chassis
pr_wainwright
Jun 2011
Stockton on Tees
109
I have 2 x 1756-A13 Control Logix Chassis. What hardware do I need to connect them together? They will be located next to each other in the control panel enclosure.
Paul.
Well, you have two choices, ControlNet or Ethernet/IP. If you go with ControlNet, you will need RSNetWorx for CN software too.
You need to use an Ethernet switch between the two chassis in any case. It will supply extra ports. For I/O control, it should have certain features such as IMPG snooping amoungst others. Whether you need more Ethernet cards depends on the devices connected an the amount of traffic on them.
HOW TO COMMUNICATE BETWEEN 2 ''EN2T'' MODULES MOUNTED ON THE SAME ALLEN BRADLEY CONTROLLOGIX CHASSIS. BUT TWO EN2T HAS DIFFERENT NETWORK. ONE EN2T...
4,344
Is this possible? I was told that there would need to be a PLC in the Remote Rack??? Why would you want a remote I/O rack with it's own PLC???
2,500
we are converting PLC-5 controls with control logix system. The idea is to replace only PLC 5 processor and retain all existing PLC I/Os. Most of...
5,344
309
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
392
