Hi All,
Having an issue on site with getting an Altivar 71 with an Ethernet module to communicate correctly with RSLogix 5000 on the Allen Bradley 104 & 103 control and output settings.
As soon as I give the drive a command it goes into "External Fault Com"
If I change the setup of the drive to use a standard control word setting on 101 & 102 then the drive works correctly.
Wondering if anyone else has had the same issue.
The only difference seems to be the structure of the control and output words, which I can change easily in the code and the fact that the Allen Bradley protocol starts on input word 2 instead of 0.
All other settings in the drive are identical when testing.
Wondering if there's something I've missed.
I haven't used the EDS file because the setup shows it as optional
