Control Logix wiring
DHADU
Oct 2017
australia
I am new to PLC world and new to this forum
We are using Allen Bradley Control Logix 1756 IO Modules.
What type of cable to use to connect from Marshalling panel terminals to IO Module for Analog and digital signals.
Like 1.5mm, 2.5mm, 0.75 mm and if we have to use multi conductor cable then what is the best part No of Beldon cable. There are so many types of multi conductor cable from Beldon.
Using 24VDC Asco 4-Way Solenoid valves to supply air to actuators with NC/NO mechanical switches to indicate open/close position of each valve...
2,455
Wiring to Control Logix I/O. I need your help to understand the following statement Wire numbers to the PLC on the following naming structure: I...
2,199
266
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
387
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
774
