Control motor pump with vfd through DMX
Serhioromano
Sep 2015
Kazakhstan
57
Let's say I am making fountain. I use Sunliye Suite 2 to make all animations of lite, including pumps. How could i transfer signal from DMX to controller or may be directly to VFD. I would not like to use analog input on VFD as I think it is not exactly sutable but I would like to use RS485 and Modbus RTU.
Perhaps there is a decoder from dmx to modbus or may be i need dmx controller with buld in modbus?
Since no one else has commented, I'll jump in:
There do exist DMX ---> MODBUS RTU modules, but they're expensive, and I've had trouble with vendors even emailing me back re. product inquiries.
0-10V directly into the drive's analog input works just fine; I've done it many times. If you need non-linear scaling and can't do it in the drive itself or in your DMX source, put a PLC with analog I/O in between the DMX -> Analog converter and the drive.
What are your concerns with using 0-10V directly to the drive?
Below is a link to a great source for DMX ---> Analog converters. I've used Northlight Systems gear for years; very robust and the price is right.
http://www.northlightdmx.com/dmx512decoder.htm
-rpoet
Here is my concern. I have SCADA or HMI. It is ok to decode DMX directly to 0-10V signal when DMX is playing. I am usinf Sunlite Suite 2. So it is for shows. But there are also times, when I need to run it statically or manually change levels on every pump. This I can do through PLC.
So in my mind I need to conect drives to PLC either through 0-10V analog output or RS485 Modbus RTU, does not matter. The point is connect to controller. Then I read DMX and convert and control drives. When there is not DMX, I simply control pumps though controller manually.
If I use DMX->0-10V decoders, I'll have to have relay on every line to switch signal from DMX to controller. In my view this is unnecessary complication.
I have found one device
https://www.adfweb.com/home/products/DMX_ModbusTCP.asp?frompg=products_16
It is around 300 EUR. It is not cheap, but if I have more than 10 pumps, I would need more than 10 DMX->0-10V decoders plus more than 10 relays and that would come about the same price.
I also found out that WAGO and Beckhoff PLCs have a special DMX master module, that is arounf 200 EUR. I might select that controller because of that feature.
So in my mind I need to connect drives to PLC either through 0-10V analog output or RS485 Modbus RTU, does not matter. The point is connect to controller. Then I read DMX and convert and control drives. When there is not DMX, I simply control pumps though controller manually.
You don't need a card per drive. The link I sent you has an 8-channel card, and a 24-channel card. That will give you setpoints for 8 or 24 drives, respectively.
If you need to switch control sources and you already have a PLC in the system anyway, simply bring the 0-10V analog signals into a 0-10V analog input card(s) on your PLC. Send your speed references to your drives via MODBUS. How you manipulate the speed reference values once they're in our PLC is all up to your program.
I'm wary of those types of converter boxes; they're expensive, and I've had trouble with documentation and programming with those types of devices before. Perhaps that converter you linked to works well, perhaps not. 0-10V is easy to understand and troubleshoot. It also lends itself to replacement and upgrade in the future; what if the supplier for your converter box disappears and the converter dies? How do you quickly get the system up and running again? 0-10V gear is ubiquitous and every vendor supports it.
EDIT: I just tried to download the user manual to the converter you linked to, and the PDF is broken. Case in point regarding bad / no documentation.
Of course, using a PLC that natively supports DMX is a great choice too. Both Beckhoff and WAGO are good choices.
-rpoet
If you are going to have a PLC in between the DMX controller and the VFDs, you can have the PLC communicate with the VFDs over Modbus or whatever protocol the VFDs and PLC have in common.
Also, do you need a true analog speed control of the pump? If you can live with say, 7 or 8 pre-programmed speeds, it can be a lot easier.
Interesting side note: I have used VFDs on fountains using their own internal "step control" functionality and through experimentation, I have found that people can detect repeating patterns of up to and including 5 steps, but only about 1/2 of them can detect 6 steps as repeating and less than 10% can detect 7 steps as a repeating pattern, they think it is random.
have a look at arduino as translator.
Here we go again...
An Arduino is a nice toy, but is in no way suited to operating in an industrial control panel. It's not hardened, rugged enough, nor does it have suitable I/O connectors for easy use.
I might accept a Raspberry Pi in a panel, depending on what it was doing - data logging, possibly some non-critical COM's translation, etc... And it would have to be installed in a case.
A Raspberry Pi could work pretty well in this application, actually: USB ---> DMX converter to receive DMX, and a either Ethernet or a USB ---> serial converter to talk MODBUS. That of course assumes the OP has the ability to program and support a Pi.
-rpoet
Thank you, jraef. This is exactly the approach I had in mind and was trying to suggest. I really wish more PLC vendors supported DMX natively. Beckhoff does, but they tend to be overkill for many applications.
-rpoet
I see. this is how I was planning to do that. I want control VFDs through RS485 over Modbus. The VFDs I am going to use are well documented and I know hot to control them through PLC. I even can change parameters. I can connect VFDs to 0-10V and RS485 and change parameter "Signal source" from analog input to RS485 and back. So when animation show is started I set to read analog input, and when I switch to manual mode, I can change parameter in VFD dynamically and user RS485 as signal source.
The main point for me that animation show is based on DMX and Sunlite Suite 2.
Regarding recognizable patterns I agree if you use reprogrammed tasks. I use algorithm that generate transitions from one level to another (random pump speed) plus time to hold in position, plus number of times to repeat this transition.
At the end I have few repeatable asme transitions but from transition to transition it never repeat. If I have 3-4 VFDs and every one works in this algorithm, you can never detect repetitions of patterns.
Serhioromano:
What jraef and I are suggesting is to connect the 0-10V signals from the DMX ---> Analog converter to analog inputs on your PLC. Once you have those value in your PLC, you can switch between using them and other parts of your program for speed reference. Send your speed reference, whatever the source, to your drives over MODBUS.
Do not run your analog signals directly to the VFDs. The DMX ---> Analog card has a common ground reference; tying the ground reference across multiple drives together may lead to strange issues and ground loops.
Bringing the analog signals to your PLC first has several advantages:
1) Shorter analog signal runs. 0-10V signals are subject to noise, so shorter wire lengths, routed away from noise sources, are best.
2) As I said above, you eliminate the possibility for ground loops by not connecting the analog grounds of multiple VFDs together.
3) You can scale or otherwise tweak your speed references in your PLC program. You may not think you need to right now, but having the ability to change scaling electronically (and within the PLC program) will be useful to you at some point.
-rpoet
This is what I want. you are right. The best way is to control VFDs from PLC over RS485. The problem with PLC analog inputs, is price. Analog input modules are expensive. And I have to convert it to analog from DMX. So it meand DMX -> decoder Analog output -> PLC Analog input -> RS485 to VFD. I convert it 2 times. First time from DMX to 0-10 and second itme from 0-10 to RS485. Why?
I think the best way to use DMX -> Serial converter. Somethign like I have already mentioned. To use Beckhoff or WAGO and it's DMX master module. It wil tread DMX signal and convert into WORD variables in controller. So in one DMX universe I'll have 512 variables in PLC. And you avoid all this potential as you call it ground loops.
Another way is to use universal DMX to Modbus TCP converter. Then you conect it directly to controller or add switch if you have additional Ethernet devices. And that is it. You simply read registers from that converter into variables on your PLC.
In my mind if I convert DMX to 0-10 I have to use it on VFD not for further conversion.
My final setup.
1. Sunlight Suite 2 DMX Controller have animation for light and water.
2. DMX to 0-10V converters are cheap and those control VFDs
4. PLC connected to VFD through RS485 Modbus RTU, and on the panel you can switch control from analog signal to RS485. Thus I even can leave light control to DMX and animate water on in PLC. The algorithms for water are much simpler to write in PLC.
Check out Yaskawa pump drive
Eliminate the plc altogether you just set the level or pressure using Modbus the feedback goes directly to the drive and the drive dose all calculations ad controls the speed of the motor
Clean simple and cost effective.
Any chance of posting a U-Tube video of the final product?
Poet.
ш have a youtube channel with the same name as my nick here. I'll post review of the control panel and then review of the fountain.
If to use Lenze, it has DMX input module. I can directly use DMX signal to VFD. But i500 Lenze cost arm and leg.
Had a vendor that builds pump control stations tell me that you could use a Red Lion cub type meter to control the speed of a chemical injection...
2,239
I'm starting on a project that will soon involve controlling two large water pumps (4160 VAC, not sure the HP). I'm curious: what generic "best...
4,529
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
236
Hey there, I just have a motor related question. I am using a 90V DC motor (https://www.motion.com/products/sku/03889770) and am controlling it...
240
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
742
