Control net tap question
Spiralout615
Apr 2022
Usa
Are you able to use the drop cable (node connector portion) of a t tap to connect to one side of another t tap to make a three way cable connection?
Question arises from the following setup:
Cabinet 1 has control net tap with two trunk cables going to other nodes, and the drop cable going to node in this cabinet 1. I need to add another node in a cabinet (cabinet 2 ) about 50 foot above this on a structure. Would I need to disconnect one side of the cabinet 1 tap, run cable from it to the cabinet 2, connect drop cable to node in cabinet 2, run another cable back down to cabinet 1, and connect this with a bullet connector to the cable that was formerly on tap of cabinet 1?
Or could I just add another tap in cabinet 1, connect its drop cable connector to a port of the existing tap, connect the existing cable to one port of this new tap, and connect the new node cable to the other port of the new tap? Effectively being a 3 way splitter. Or does AB make an actual 3 way splitter?
No, you must use one Tap per node device with taps connected to the trunk.
Drop cable must go directly to a node and can’t be extended beyond its length.
ControlNet tap has some electronic components inside, this is not a just a splitter.
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
210
An outside contracting firm designed a machine for our company. There are several devices connected through Ethernet/IP. This includes a Panel...
194
I am getting random comm loss (error code 561 i think?) anyway i looked it up and its loss of comm to 2 modules on a controlnet network. The 2...
353
Hey everyone! I'm searching for an example demonstrating how to program in Studio 5000 speed control of a PowerFlex 525 drive via Ethernet. While...
658
Hello, So I was asked to turn up the speed on a VFD to allow a carriage to move a little bit faster and avoid getting stuck. Im not sure the exact...
743
