Controlling a sequential call on a product delivery system.
Qubit
Jul 2010
Newark
Hi
I have a conveyor belt with product running along it. There are 8 pushers sending product to 8 workstations when the operative calls for it. This much I can program myself.
The difficulty is trying to get the PLC to memorise the order in which the call buttons were pressed and and deliver the product to each on in sequence.
Sometimes all 8 stations will be in use and other times maybe only 2 or three.
Any help much appreciated.
I'll be using an Omron PLC, probably a CPM2A
Is there a simple command to make a FIFO circuit or does it need programming separately.
I've never used a shift register before and was wondering if I could utilise one in some way.
Thanks for helping.
I just had a thought. Would it be possible to use 8 Data memories and shift the queue across them as the product goes to each operative. I can't exactly work out how to do that but I think it should be possible.
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,773
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
115
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
500
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
184
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,069
