Controlling ATV 320 VSDs with a Modicon m221
tspark
Jan 2019
Preston
Hi there,
Im having difficulties, controlling ATV 320 vsds over Modbus SERIAL RTU with ioscanner from a M221 with so machine basic,
Iv followed all literature I could Find but to no avail can I get any communication, Im trying to use the Pre made functional drive blocks,
Im pretty sure my connections are all correct with the necessary end of lines on the RS485 side of things, and the drives are addressed correctly with correct baud rate etc and their commands set to be received on modbus
Can any body see what im doing incorrectly?
Cheers Tom
https://nh5u3q.db.files.1drv.com/y4...kUPlzvLA?width=1920&height=1080&cropmode=none
https://k365aa.db.files.1drv.com/y4...Xb9nzzkA?width=1920&height=1080&cropmode=none
https://lh65aa.db.files.1drv.com/y4...Sa45CaEw?width=1920&height=1080&cropmode=none
A copy of the program for so machine basic below:
https://onedrive.live.com/embed?cid...DD900AE358E74ECF!8673&authkey=AFoMVsnTiZMFZF0
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
115
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
510
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
184
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,071
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
344
