Controlling two tags with same button in Rockwell Factorytalk View
rtragle
Jul 2015
Bakersfield
19
Is there a way to control 2 tags with the same button in Factorytalk View?
Background:
I have a motor that has auto enable and manual enable tags. When I shut it off, I have to change both AUTO_ENABLE and MAN_ENABLE to false.
Thanks,
Ryan
Is the macro capability new? I'm using version 8 of Factorytalk, and it seems like macros just assign values to tags with no parameters
--Ryan
No, it has been around since the RSView days.
Are you using it with a Panelview Plus, or a PC? If the latter, is it SE standalone or distributed?
--Ryan
It has been a long time since I have used the software, but there are Macros, and then there are Macro Buttons. I think you set up a Macro with multiple lines, one for each operation, and then use a Macro Button object to call the Macro.
Don't do this in View. Do it in the PLC. Seriously.
Write one momentary bit to the PLC, and use that to disable/unlatch/whatever both modes. Then, again, in the PLC, forcibly reset the command bit from View. There is absolutely NO guarantee when using FTView that a bit will actually be successfully written, and even less of a chance of writing two at once.
Don't know if this will work in your logic, but...
We use "Interlocked Push Buttons" to change modes. For instance if we have a component with 3 modes (off, auto, on) we will use three interlocked push buttons displayed side by side. The OFF button will write a 0 to the target IND or DINT, the AUTO will write a 1, and the ON will write a 2.
We then use that INT or DINT in an EQU to determine which bit (off, auto, or on) is energized.
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
115
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
505
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
184
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,071
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
344
