Controlling VFDs with Fx2N. Help needed
farooq.gill
Oct 2014
Lala Land
What are the different ways to communicate and control VFDs using FX2N PLC?
Is there any special function module for this? Please refer me the required manuals. Thanks
Analog/digital
Profibus (with added module)
What drive do you have and what model of FX2N do you have?
Actually I have to automate a machine. All the inputs and outputs are digital. But there are 2 inverters(L100-002MFU2 hitachi inverters). what hardware you suggest then? Try to give me the manuals link if you can.
I second the above. If you don't really know what you are up to. Use digital/analog signals. You won't likely need anything, unless you don't have spare outputs.
I am not going to spend time googling for you. (Unless you want to pay me to do it ;) ).
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
126
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
527
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
192
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,104
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
352
