Controllogix 1756-L73 firmware
Jim G.
Nov 2007
Georgia
187
I have an AB 1756-L73 processor that I want to use to replace a L62. I have the L73 hooked up to a spare rack on a bench and have updated the firmware to 19.xx which is the same version in the program I want to download. I have downloaded the program and everything looks OK for the swap out. The L73 has the old L62 program converted to L73. All the firmware update and program download was done via USB. The L62 in the system running is Ethernet. Will the L73 plug right in the system rack and run or are there other things to consider before swapping processors. Thanks.
You should be good. You will want to make sure all of the IO and ethernet devices connect properly to the new processor. But again there should not be any issues.
We have a project where we have the 1756-L82Es in redundancy with Remote IO Backplant via EN2TRs. Everything works and is redundant but we can...
379
Hi there! I posted few days ago about a fault i had with my motion. I did some cable check and replacement and it didnt solve my problem yet but...
378
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,081
PN1651 - ControlLogix 1756-OF8/B modules may exhibit spurious channel 4 through 7 faults. Rockwell just released this and we have an upcoming...
1,078
I was wondering if anyone else has had issues with the PA75 bricking on power ups. We had 2 that were a year old brick on us. 1 bricked when the...
870
