huvalderrama
Hi, I have been trying to connect ControlLogix with a Parker Drive (SSD 590+) using a LINKNet Card; the PLC is a L61 in Redundancy over ControlNet, in the IO Rack (3rd) is an ENBT/A card that should be used to communicate with the HMI and the Workstation, but now a Drive is added and the Parker Drive has documentation on how to used as an IO in the Ethernet Module, which work perfectly, but no in the redundancy with ControlNet, so I tried to communicate with the Drive using explicit message, but no success, I guess (not an expert) the comunication a an IO is UDP and the explicit messages are TCP.
Do you may have any recomendation I captured the Packets using Wireshark and check the communication with the PC Software of the Drive.
but not sure that I can generate UPD Message using the ENBT/A
