Hi Guys,
I've got a problem with a ControlLogix 1756-l61 controller where Watchdog Fault - Periodic task overlap is causing problems.
However it appears that the Priority 1 task (which normally takes 5ms) which is our I/O task and does nothing but map some digitals and analogs is occasionally taking up to 500ms scan time (which is the watchdog limit).
My understanding is that nothing should interrupt the Priority one task (not using motion planner) and as such there is no way that the I/O task should take that long. Is this correct?
So it would appear that the CPU is due for replacement (10 years old) ?
Thanks for your time once again!
