Controllogix With Remote I/o Adressing ????
mechatronic
Jul 2007
SERRA
Hello everybody, I am new, here and new in the automation area too 3 months off working.
I am having a problem, two guys left a program in my hands to do a start up on next week.
In this project we are changing the PLC-5 for a controllogix, but we are going to use the I/O of the PLC-5 with remote I/O modules.
My question is about how to adress the remote I/O in the CONROLLOGIX, the guys that made the program configured the RIOs rack as a 2-SLOT adressing, and they didn't used the rule (IN card | out card). I looked up in the forum and saw some threads about 2-slot adressing but all off then refers to 16 in and OUT cards, but in my, case they are 8 in and 8 out cards.
I will put the picture of the configuration they did in the program i whant to know if i will have to change the adressing mode they did to single slot or no?
In a word.... NO. If they work on the PLC-5, they will work on the ControlLogix.
If the I/O cards are the old 8-point cards, it was very common to set them up with 2-slot addressing. There is no restriction for which cards are inputs and which cards are outputs as long as they are all 8-point.
Now, if you start adding 16-point cards to these racks, then you must avoid putting a 16-point input module in the same module group as another 16-point or 8-point input module. (Same thing applies for output modules.)
Bottom line, the new ControlLogix program should match the way the racks are currently configured or you will create a whole lot of extra work for yourself.
Hi all, I need to bring in a single AI (temperature) from a remote location (2 miles) into a Controllogix PLC. Any simple cheap suggestions...
18
930
Hey All, I'm currently building a control system for a large building in a industrial setting. Doing lighting, vent, roof control, door access...
3,513
Hey everyone, ran into something I've never seen before and was wondering if anyone had any idea of what's happening. Currently in the middle of...
2,074
I have a Redundant ControlLogix L61 System running on firmware 16.52. There is an existing ControlNet network for the ControlLogix IO bases but we...
3,138
I have a Control Logix PLC and Safety PLC , 5581ES and 55L8SP respectively, pulled out of a cabninet connected to a Panelview Plus connected over...
1,571
