ControlLogix Wonderware bit level addressing
Psymon
Jul 2004
Wisconsin
111
I have a PLC5 program that I converted to Logix5000 platform with the automated translation tool. Everything went fine with that, but my problem is the Wonderware. I was just going to to a DBDump and convert all the tags in Excel and do a DBLoad. Problem is that all of the B addresses were addressed in bit level not word/bit, so everything is B3/145 instead of B3:9/1. So my question: Does Wonderware allow you to address things on the bit level to a ControlLogix? So if I put in B3.145 would that translate to B3[9].1? Or is my weekend shot?
Thanks all,
Jay
Side note which I thought was kind of humorous. Whoever programmed the Wonderware must've been a superstitious fella. He never used bit 13 for any of the tags. Really had to double check to make sure I wasn't missing something on that, but alas, no bit 13's anywhere. :confused:
Yes, Wonderware will address a CLX to the bit level as you ask. Bits are {Tagname}.bit.
FYI: Make sure you have the latest version of your WW I/O server. We've experienced some issues with older versions that read the CLX Array B3[9] as B3[7], B3[8] as B3[6].....B3[n] as B3[n-2]. We never did figure out what it did with B3[0] and B3[1]. It was all quite baffling until we discovered the offset - and still quite confusing until we tried updated the I/O Server. Once we updated the I/O server, all was good.
Jay, I don't think that's what he asking. B3.145 will not translate to B3[9].1 in ww. What I've done before is export the tags to Excel and then write a formula that would calculate the number of whole integers and the remainder and combine them into the right format.
Hi everyone! Hope you all are doing great! We have a really strange issue with comms between Wonderware and a controllogix L62, we use an...
1,712
I’m using an AOI in a Rockwell PLC for a device but this older, (non-Archestra) version of Wonderware apparently doesn’t recognize “dot” tagnames...
1,630
Hello Everyone! Need help with this... I have a controllogix plc 5571 which has just a USB port on it. I wish to read the data from this plc...
2,393
Hi everyone, I'm working with the Wonderware ABCIP driver to connect to a few ControlLogix PLCs. I've configured the driver for the L71, but I...
2,583
This ControlLogix PLC is located remotely via fiber. At the PLC location, the fiber comes in, goes through a "BlackBox" converter, then out to...
3,973
