ControlNet between a non-AB PLC and a remote AB module
Salman S.
Oct 2016
Malaysia
41
Does anyone know if its possible for a Non-Allen Bradley controller to acquire IO data from a module in an Allen Bradley remote rack (lets say a modbus module in CLX), via ControlNet?
As always, any help is much appreciated. 🤾
Additional info: I don't have the required hardware to test the setup, so its more of a question of validity.
I cannot say with certainty, but usually anything that requires communication across the backplane would be AB only.
Since we aren't doing specific hardware in this scenario, I would guess that what ever PLC was chosen would be able to communicate with an AB PLC in the rack. And that AB PLC would be able to be used to pass the data from the card on the backplane?
Or is this a hypothetical where no AB Plc exists and you would be attempting to use an AB backplane with the controlnet bridge and modbus comm card?
I don't have the hardware, but it is an actual setup proposition.
The hardware involves a Honeywell C200 communicating with an AB chassis(no controller) with a CNET card and a 1756-MNET card.
So essentially is it possible to pull data using Honeywell C200 from the remote MNET card? The data path will basically be:
MNET card --> backplane --> CNET card ---> CNET ---> Honeywell C200.
I know that GE, at one point, made an AB IO interface module for Series 90 PLCs. I think that it was for a Blue Hose Remote IO interface. I would imagine that there are still some third party interfaces for AB IO, although I haven't personally encountered one recently.
Hi Guys, I have run into a little snag here will laying out my system architecture on paper. I have two redundant sets of controllers that need...
3,070
I have a ControlLogix system using ControlNet to connect to the remote I/O. I am using 1756-CNBR modules with redundant media in both the CPU and...
13,155
Hi, I have a hardware setup of CLX, ENET, CNB, CNB, IB, OB in a 13 slot rack. This is duplicated on another rack and the ControlNet modules are...
3,720
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
209
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,312
