ControlNet to Wonderware System Platform
drhano
Nov 2010
REgina
im trying to retrieve data from a controlnet network through an HMS Anybus Gateway X convertor into Wonderware system platform with no luck. Does anyone have any experience with this?
THanks!
Some questions.
What IOserver are you using DAS?
What protocol are you using? Modbus TCP?
Explain you architecture a bit better in regards to your setup it could be many things..
Rheinhardt
Hi drhano,
Can you be a bit more specific as to what is not working.
What type of gateway do you have (AB????)?
Have you configured the gateway through Hyperterm? If not, the gateway will boot up with 20 Bytes In and 20 Bytes out.
Is the gateway online on the ControlNet?
Are you using Modbus TCP on the Wonderware side?
//PatrickL
Here is some more information on what we are trying to do here.
on the ethernet side we are using communicating via EthernetIP through the ABCIP Data acquisition server (DAS). Set up through the system management console of Wonderware.
The gateway we are using is a HMS Anybus Gateway X. http://www.hms.se/products/abx.asp
On the controlnet side, there is a single PLC5 connected to the Anytbus Gateway.
Hope this paints a little better picture of what we are trying to do here.
Thanks!!
Sorry to say but I would need more info...
Probably it would be better to contact the support dep in our office in Chicago:
Anybus Support
Mr. Randy Dang
Tel: +1 312 829 0601
Hello all-it's been awhile. We recently bought a used machine and have made some modifications. The original machine had a Wonderware computer...
1,399
Migrated a PLC-5 to Logix yesterday. The new Logix communicates via Ethernet but there is still another PLC-5 communicating via ControlNet...
31
10,475
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
228
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,327
I'm having an issue trying to backup a ControlNet network. Within RSLogix5000, when I click on Module Properties of the 1756-CNB (Rev 5.001), the...
879
