Contrologix processor and MSG instruction
Christoph
Sep 2003
Indiana
345
I am adding a msg instruction to do a SLC type read to a
SLC 5/05 from a control logix both sitting on our network. there are several msg commands in the controllogix all ready and functioning.
when I have added a msg command previously and now
the conditional bits preceding the msg command don't toggle.
(DN ER EN) what am I not doing correct.:confused:
Make sure there is a condition on the rung that makes the message read.
I always use a timer that reads or writes the message every xx seconds.
If you have the message on an unconditional rung the MSG instruction will not work.
Mark
I am working for a company that does chrome plating and the line is VERY old lol So they did a controls upgrade(before my time here) and replaced...
1,798
In the Contrologix User manual in chapter 8 it says versions 15 and forward have the ability to add I/O online without having to stop the...
2,853
Is there anyway to determine via GSV instruction that edits occur in a 1756-L63 CPU? We are having a timing problem with our Ignition...
2,781
I have an application where I am doing a MSG read from "PLC_A" reading "DINT_1" in "PLC_B". What happens if PLC_B faults? Will the MSG read still...
2,633
Can anyone confirm that using contrologix 5580 controller is not possible to work with powerflex 527? It's been a couple of days now that i am...
1,204
