Conversion from PV550-600 to PV800
Oliver Micka
Oct 2015
Hlohovec
65
Hi everybody..
We have a lot off oldest HMI ( Pv550-600 ). Many HMI is in end of life ( spare parts and repairing is very cost )
We would like replace this type HMI to a new PV800 ( 2711-T7T ) ..
So .. Are exist any utility to conversion? From PV550-600 ( PanelBuilder32 ) to PV800 (CCW) ?
One piece i musted creating manualy from begin ( one piece is not problem, but 20-30 pieces is lot of time )
Many thanks.:)
Is it not the case that you can import the old application into FT View Machine Edition?
You can directly import pba and pva files and it carries out a conversion for you.
There will be items to check on the conversion, but I saw a demo and it looked pretty good.
What communication is currently in use on the older units between HMI & PLC
There is a conversion application in FT VME as JohnCalderwood stated however if your present comm's is something like RIO or Controlnet You might have difficulties with comms modules on the newer HMI's I haven't used the 800's but converted a lot of older Panelviews that were RIO and ended up just re doing them manually. The older models were crude and the conversion doesn't allow you to utilize all the newer functions.
It is completely different programing but once yo get the hang of it it will go quickly.
Personally I use a WEINTEK HMI it is more cost effective and software is free.
Side Note:
I also convert everything to Ethernet when I upgrade the HMI
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
124
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
104
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
