conversion S5 to S7 LIR1???
aymen
Mar 2009
tunis
Dear all
i wont to convert this pieace of S5 instruction to S7 which contain LIR1 :
FB234
nom :DASA
Design EQNR E BY
L =EQNR
B MW 196
A DB 0
L DW 9
TAK
< F
BEB
L DW8
: F
T MD 250
L DW6
+F
LIR1
As I Know to convert LIR1 i must have value of accumulateur1 which is the conserned adress so LIR1 is replaced by the value of this adress.
but using only the programm and i know that the plc is related to an old op 3XX ,how can i resolve this problem??
(i think that i have to know the realtime value of (mw196,dw9,dw8,dw6) which is only possible if i am near the PLC????)
thnaks and best regards.
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
89
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
124
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
106
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
285
