conversion
Tim J
Oct 2002
Walled Lake
We are using an Allen Bradley 5/04, an Ultra 3000 drive, and a PanelView 550 all communicating over DeviceNet. I have taken the drive data and converted in from double integer to floating point, (so we can scale it) and now I have to convert floating point back to double integer (so we can send it to the PanelView). Has anyone accomplished this? If so, I would appreciate help in the matter.
Thanx,
Tim
You should be able to display this data directly on the PanelView, either as 4 bytes of the PLC/PV I/O connection or as an explicit read from the Ultra 3000 that is triggered by the PanelView.
What value, exactly, from the Ultra 3000 are you trying to display on the PanelView ? I can probably give a good example of just such a configuration.
thanks for your reply, I found a coversion example on the AB knowledge database. very close to 1 I had been working with myself to convert DINT to floating point & back.
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
228
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
109
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
138
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
112
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
307
