Converting fahrenheit to celsius
Cajunman0821
May 2004
I am currently running into an issue where I need to convert my fahrenheit set point to celsius. I am storing the values in BCD and need accuracy to the tenth. If I have a value of 682 this is actually 68.2 degrees F. It should be converted to 20.0 degrres C.
Can anyone please help?
C = (F - 32)/1.8
If you are using a factor of ten to get an assumed decimal place, just mulitply the whole conversion by ten:
Cx10 = (Fx10 - 320)/1.8
Fx10 = 682
Cx10 = 201
If you can't handle the decimal in your PLC with a floating point, use another factor of 10:
Cx10 = ((Fx10 - 320)*10)/18
Fx10 = 682
Cx10 = 201
Fx10 = 2120
Cx10 = 1000
You don't identify the PLC model you are using, so the details will vary, but this can be done with the simple four function math available in most PLCs.
I need to convert a RSLogix Program from Celsius to Fahrenheit, I have had the file on here before and was going to look into a different way to...
18
5,444
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
321
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
391
