Coonected Componentes Workbench: Is it possible to know the version of a .CHA file?
asteroide
Jul 2010
der
158
Hello friends.
I have gotten a .CHA file from a PC backup. It is from a Panelview Component C300 (2711C-T3M).
Nobody knows in what software or version was made.
I have tried with CCW8:
File/Import Device/PVc application...
But a message appears:
"Import PVc application not successful."
I guess if I have the lastest version of CCW, I should be able to open old version, but this does not happen.
Also I have tried with CCW7 and CCW3, but without success.
Is it possible to open in another way? or should I install every version (CCW6, CCW5, CCW4, ...) until it opens?
Best regards
I rarely use ccw so I'm not familiar with versioning issues but if you want to post a link to a file (or pm me a link) I'll investigate if there is a way to tell the version.
Problem solved¡
The issue was that the extension was in capital letters .CHA
Should be .cha
Thank you for your help
Glad you found the issue and thanks for updating the forum. Hopefully they know of the error and fix it in a future release. Seems silly that the file extension is case sensitive.
BTW, I created a project and exported it to .cha. I right clicked on the file and opened it in a text editor (Notepadd++) and it appears to have the version in the first line after the device. Mine has a bunch of nonsense, then I see "2711C-T10C 6.0". Not that it matters to you now but if you are ever curious...
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
838
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
515
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,305
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,083
