Corrupted Processor SLC-5/04
alondra007
Oct 2008
Lake Mary, Fl
18
I am uploading the program from a SLC-5/04 and i am getting this message "CORRUPTED PROCESSOR". The plc is running with no problem, working fine but i cannot upload or go online with the processor.
What can i do to fix this?
If you are using a SLC 5/04 Firmware 10 you need RSLOGIX500 v7.1 or higher. If you use a lower version you would get the error message Corrupted Processor.
Conntact your local AB dealer and they should be able to help you my friend
Has anyone seen this before & found a way around it? 1747-L553 Processor. Working now with no problem, except I can't talk to or save the file...
3,015
Hi, we are using 5/04 processor and when we are going online it is showing the processor is communicated in RS Linx. When i select the processor...
2,212
I recently setup RSLOGIX 500 v6.10.10 on a new laptop running windows 7 pro. When I attempted to go online with a SLC5/05 via ethernet I get an...
2,942
I am trying to connect to a PLC but i'm getting the 'Corrupted Processor' error. I am using Logix500 v6.3 so I believe its out of date with the...
2,090
Hi all, We have a Allen Bradley SLC5/05 that has a fault light that is on constant and the remainder of the lights are flashing. Also, upon...
3,017
