**** Cosy - moving to another account
johnd_125
Apr 2012
Missouri
146
I have a Cosy 131 on my free account and need to delete it and make it possible for someone else to add it to their account.
The issue is this device is in South America and I have my doubts there is anyone local who could add this device to another account using the activation key. I've always used the activation key, locally, but seems like the ability to change accounts remotely is something that should be possible. Perhaps with help from tech support at ****?
Can this device be added to another account without local access? If so, how?
Whenever I have needed to do something like this, I get someone with a laptop connected to the COSY or FLEXY, as well as the internet, and take control via teamviewer.
Typically during setup, I always link the account using the Talk 2 M credentials. I have already switched accounts remotely using that method. After sending the changes, I lost access in the original account but was then able to login from the new account.
Certainly comes with the risk of not re-connecting to the new account, and I'd recommend testing on a local unit first.
The other method you could consider is using the USB / SD setup method. Haven't done this personally, but I believe the owner of the new account could create the setup USB in eCatcher then ship that to the site. Someone locally then would need to finish the setup.
I have done this once.
I followed the instructions here.
From the link, copy the following text into a txt file called "remotewizard.txt". Replace the xxxxx with the activation key for the new Flexy entry in eCatcher.
Use FTP to place this file in the /usr/ directory.
:main
wizardname:t2mCnx
:com
T2mAccSrvAddr:******_pro
:wizard
T2mActivationKey:xxxxxxx
The text was censored, please see the attached screenshot for the correct second text field.
wj6W65N
The link mentions that this cannot be done anymore as the device must be deleted from the current account before being able to connect to a new one.
I uploaded this file, told the device to reboot. Immediately disconnected and deleted the device from the old account.
It took a few minutes to show up on the new account but it did work for me.
o_OIF YOU FOLLOW THIS AND IT DOESN'T WORK, YOU WILL NOT BE ABLE TO ACCESS THE DEVICE AGAIN.🔨
So attempt at your own risk.
Thanks for the input. FWIW, I think they had someone local install ecatcher, connect to a local port and then they remoted in to that computer to add it to the new account.
Dear all, hope you are well, i will buy cosy 131 to get remote access to controllogix chassis.any one try to use it. and for talk 2 m free cloud...
1,770
Has anyone used an e*WON Cosy with AT&T? I have a sim card and a data plan but for the life of me cannot get it to successfully connect to the...
2,021
Hi all So on one of my remote installations with a PV 7 I have an HMS e w o n 4G Cosy coupled with it to giev remote VPN access, the customer has...
2,355
Hello, Currently my company is trying to connect our PLC system to the E W O N vpn. The PLC system runs off of CANOpen 2.0A, the e w o n has a...
1,273
I have been tasked with adding an additional PLC to an existing Schneider TM221 is fully utilised, setting up communication between two m221s is...
1,650
