E WON Cosy additional Lan
smiley125
Apr 2014
UK
I have been tasked with adding an additional PLC to an existing Schneider TM221 is fully utilised, setting up communication between two m221s is my next challenge but that's for another time.
On the existing system theres 2x HMIs and 1 plc connected to the E WON along with the WAN connection, the new PLC will also require a LAN connection so i was thinking i could use a network switch to give me additional LAN connections as all my equipment will have fixed IPs.
Has anyone done this before and have any experience or tips, or even a better way of achieving the same thing?
The Panel is in the states and we aren't or i would just plug one in and try it.
(short version) Can i add a switch to the LAN side of an E WON Cosy to give me additional LAN Connections?
This may be a bit of a random comment but I was working with the e.WON and a switch. I have used the 5 port Phoenix contact switch with no problem, RS 712-4046, but had all sorts of problems with their 8 port version, RS 712-4049. The RS own brand 8 port came to the rescue. I emailed Phoenix Contact tech support over a month ago, but didn't get any reply. I realise that the likelihood of you using the 8 port Phoenix switch is probably very slim.
Dont use the **** as a switch. Supply a good industrial switch to run your devices then run one LAN cable from the **** to the switch. I dont know the specs of it off hand but asking the **** to be a switch would probably be bad, I would guess that development time was spent on making it a powerful VPN and not a powerful switch.
Has anyone used an e*WON Cosy with AT&T? I have a sim card and a data plan but for the life of me cannot get it to successfully connect to the...
2,020
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
98
Does anyone have any experience of using an ***** Flexy for remote programming/maintenance of a Codesys based controller? Rather than using the...
231
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
958
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
667
