Could it cause electrical hazard if I connect as diagram below?
cocoroco89
Mar 2016
Kitchener
Hello,
I need to use 220VAC to connect DC power supply. As you can see it is center tapped transformer and ground is connected with center tap. Would it be fine to connect X1 with L, X4 with N and ground with G on DC power supply? What would be the safe way to wire to use both 110V and 220V?
The wiring diagram looks fine to me. The way it is supposed to be connected.
Not sure what you mean by using 120 and 220 at the same time though.
Your drawing depicts a normal 120/240V distribution.
If your power supply is rated for 100-240V as many are it should be fine.
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
78
Good Morning , Not sure how many use Markem-Imaje SmartDate X60 Printers , but I'm having trouble finding a good manual for...
644
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
360
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
841
This is a program in a machine that has been running for about 7 years without any issue like this. We have a master servo (the machine's main...
1,171
