Couldn't find the 315T-2DP in the catalogue
hagos
Oct 2004
Africa
244
Dear Folks,
I'm trying to configure a 315T-2DP CPU (6ES 315-6TH13-0AB0), but I couldn't find it in the HW catalogue.
I'll appreciate if some one can help on where to find it.
Many thanks & regards
Hagos
hor configuring that you need:
STEP 7 V5.4 + SP2 or higher and S7-Technology V4.1 option package
So I would guess you are missing the option package?
In HW Config check the hardware catalogue selection profile. (Just above PROFIBUS-DP). Most probably Standart is selected. You should change this to Simatic Technology-CPU. Then you can add your T CPU to your project.
What is your application with Tech CPU? In Turkey T CPUs are not popular but I am curious over them. How do you program Tech Blocks? In what application do you require T CPUs?. Thanks.
hello, I'm working in a project on TIA Portal V13. when I tried to configure my hardware I couldn't my CPU. I checked the compatibility of Siemens...
2,684
I am setting up a laptop with Windows 2K and Windows 98. I was able to find the PCMK driver for Windows 2K but not Win98. Can anyone provide me...
7,210
Hello, I have Allen-Bradley 4100-234-RL IMC-S/234 Compact Motion Controller, I could connected to controller, but I unable download application...
1,791
Just wanted to post this for anyone who might run into this issue in the future. A couple days ago, I tried to update the RSLogix 5000 that I have...
20,644
I'm doing Hardware configuration on Step 7, S-300, 315-2PN/DP. Insert couple of DI, DO AI and AO module. When I assign them address, I assigned...
18
2,948
