CP 343-1 Ethernet communication with Cimplicity 6.1
jdram82
Mar 2008
Dear all,
I have built Siemens S7 300 Panel with following hardware modules:
Simatic S7-300 CPU 315-2AF03-0AB0
Communications Processor 343-1EX10-0XE0
I have made the online communication between S7 300 and Simatic Manager using MPI.
but when i am trying to communicate from CP 343-1 using GE cimplicity HMI i am able to ping the IP address of the CP 343-1 but could not get the data from it.
What are all blocks i need to add in the PLC program for this communication.
Pls share the Configuration manual for the same.
Kindly help me in this regard.
Durgaram
Hello everbody, I try to communicate cp343-1 ethernet card of s7-300 series with the Wonderware Intouch. My scada versions is Intouch9.5. This...
12,010
I want to sent with AG_Sent(FC5) multiple strings to a display that is stored in DB1. If I 0.0 is true string 1 in de DB where sent. String 1 is a...
3,427
Send/Receive Data(ethernet comm..) between CPU 315-2 DP & S7-1200 OVER CP 343-1 Lean I have 2 programs. In 1.(first program ) my hardware...
2,690
Hi! I have a question regarding ethernet communication with a Siemens S7-312C and 343-1 Lean. For some time I´ve been using the S7NetPlus...
3,304
Hello, I am trying to setup an ethernet link between a computer running WinCC Flexible RT (2005) and a CPU317 via CP 343-1. I believe I have...
4,014
