CP1430 NOT SYNCHRONIZED status
From the manual:
if you want to re-synchronize all the interfaces:
– First set the CP 1430 TF to STOP using the mode selector.
– Make sure that the correct number of SYNCHRON HDBs are triggered
on the PLC.
– Set the CP 1430 TF to RUN using the mode selector.
STOP AND START the CP in COM1430TF?
Yes, many times
From the manual:
on the PLC.
Don't work too
In CPU only green LED, in CP Green and Red LED.
For COLD RESTART I try in Step 5 (C Restart) and in CPU I hold the reset switch in the RESET position and in the same time, switch the mode selector from STOP to RUN
Hey, Does anyone have an idea how to set up a poll job on the CP1430 so that the SIX driver installed on my pc can poll for data blocks on the...
1,664
Has anyone experience in configuring a connection between WinCC and S5 with CP1430 card in S5. What are the step to setup communication?
1,542
Current setup My Current S5 system has 2x 928 CPU's and 1x CP1430 communication card in the rack. The CP card only allows me to connect to CPU1...
1,898
hello how can send me this softweare ? and i need to know the steps of downloading a data base to CP1430? and i if there is also a special...
2,127
Hello PLC / SCADA guru's. I have a problem getting an connection online. I want to connect with SCADA softare Wincc V6.0 SP3 with an...
4,971
