Creating a Selector in Function block (Rslogix 5000)
remullis
Oct 2012
Georgia
179
In function block programming I am wanting to be able to select from 4 different flow meter tags to point to an equation depending on the mix tank we are using. I will add this discrete select button in Wonderware.
I tried setting this up with the SEL function and I can toggle between two tags but for the enhanced SEL I am not sure what its looking for and how to setup multiple tags and be able to select using a discrete. Once selected it will wire to a math equation I am using for ratio.
Rich
With the ESEL, you don't select with a discrete. You use the ProgSelector input when under program control. Send it 1 through 6 to pass through inputs 1 through 6. Set it to 0 to make no change in the output.
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
695
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
76
Hi everyone, I'm a last year student at the university in Ghent, and for my thesis i need to write a TwinCAT program that writes data to a .daq...
144
When I go to create a new module in Studio 5000 I can't enter any information for the IP Address or change any other fields. Is there any fix to...
255
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,069
