Creating Routines in rs logix
Nelliyan
Sep 2011
90
I am trying RS logix 5000 emulator to perform a testing task .
While i am doing this i got 2 problems
1) How to create FC & FB first .There is only MAIN ROUTINE how to create new fc & Fb .. if i right click the program & create new routine a function was included but it shows it as main only...
still i just added a coil in that function & while calling the routine using JSR ... that coil got energised but while the routine was not called still the coil inside the uncalled routine was on, it must be off if it was not called ,but it s on:confused:
2 ) How to address the analog values & in which registry these has to be read
in siemens i will configuring the address location of that specific AI or AO( id 0 , id4 , aiw0 , aiw4 like this) while configuring the channel itself ,,, here can't find such thing only this show to take the channel as 0 to 10 v or 4 - 20 ma .. where to read these values
Regards,
Nelliyan.G
Does GE fanuc 90-30 PLC(CPU 364) support Interrupt routines? if yes, How can I make an Interrupt routine using VersaPro??
3,940
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
700
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
78
Hi everyone, I'm a last year student at the university in Ghent, and for my thesis i need to write a TwinCAT program that writes data to a .daq...
146
When I go to create a new module in Studio 5000 I can't enter any information for the IP Address or change any other fields. Is there any fix to...
256
