Crimson 3.0 Bug?
berndu86
Aug 2015
Cleveland
I am just starting out trying to get up to speed teaching myself Crimson 3.0. I am having a problem when I go into the emulator. When ever I drag a symbol on to the screen and go into emulator mode, the graphics are skewed or messed up for lack of a better term. Primatives are fine until I stretch them diagonally. When resized or stretched diagonally, the graphics are also messed up in emulator mode.
Is this a bug with Crimson 3.0? I tried reinstalling Crimson. I am stuck trying to figure this out. Help! (please)
The Crimson 3.0 emulate has graphic issues (known bug, confirmed with Red Lion) ... I had the same issue. I assure you that it will look okay on the HMI itself.
There seems to be a bug/problem with the latest version of Crimson 3(Build 418), with regards to the switches. When I use a 'toggle switch' or...
5,466
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
229
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
91
