Crimson 3.0 - G304K data tag storage
kenvandenberg
Mar 2006
California
23
was working the same file on two computers (home and work) and noticed that the tag values were not copied with the file.
the tags were marked as retentive, but had different values on each machine, when i moved the file between computers the tags kept the values of each computer.
are they saved in a different file on the G304K?
Data values of retentive tags are not stored in the Crimson file, nor in any other file on your PC. Crimson simply allocates Flash memory in the G3 unit for retentive storage of these variables. (This is my experience with C2; version 3 may behave differently.)
Kolyur is correct.
If you run the emulator, the retentive tags are stored in the memory image file under...
C:\Documents and Settings\UserName\Local Settings\Application Data\Red Lion Control s\Crimson\3.0\Emulator
...but that still won't follow you from PC to PC.
My understanding is that crimson 3 can be used on the G304K. The HMI that i have has crimson 2 runtime and the Crimson 3 gives me the Do not...
2,036
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
260
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
114
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
100
