Crimson 3 build 217 comm problem w/ml1400
suBrett
Aug 2009
Union
Hello All,
Long time reader, first time poster. Love the site and have learned a ton of useful info. I'm hoping to find an answer to this problem.
I have a small application w/ml1400 and a g306k, only about 28 tags, comms setup for etherip on a private network. App worked fine in Crimson 2, then when C3 came out I wanted to move to that. The first build I got was 207 and I made a bunch of cosmetic changes and all was fine except for the issue with the ALM light staying illuminated (discussed in other threads here). When b217 came out, I noticed that that issue had been addressed in the release notes so I upgraded.
At that point I have a blinking COM light and no communication to the ml1400, no changes to the Crimson DB. I have removed and reinstalled b207 and b217 a couple times with consistent results.
No DB changes, b207 works fine (except ALM light) and b217 has no communication.
details:
prog port, com port, aux port - not used (no driver selected)
network port enabled - manual config all others at default
Proto 1 - DF1 Master via PCCC/EIP
PLC1 - enabled, ENI/Micrologix, address correct, all others at default.
Any insight would be greatly appreciated!
Thanks,
Brett
I had a G306 running Crimson 3 build 419? and when I tried to use the TREND screen the unit would reboot. So I downloaded build 515 and put my...
28
5,316
This is a question more for a Redlion Tech-guy: But I have just noticed that the latest version of Crimson 3 (Build 493.003) has an update which...
1,963
In this new build, anybody knows what is the "ability to use a custom landing page for remote view"?
3,878
Just downloaded the latest build (469) I opened my latest project and hit verify...just to see what would happen...normally I would expect it to...
1,953
Hello all, I'm using Crimson 3 Build 418, and one of updates was "Fixed random reboot problem". Even when I've noticed there are much less random...
6,252
