CSVDatalog Active X/ME DataStore Plus bug?
JZerb
Oct 2016
Here
423
Setting up a CSVDatalog Active X the other day on a PVP7 standard and came across an issue I'd like to share. To keep it short and to the point, under the Advanced tab in the Datalog Properties for File Headers I chose "Template". I made a template .csv file in excel and loaded it onto the PVP. Triggered the datalog from the PLC to test it, saw the trigger bit go high on the PLC (I setup a test screen to make sure this was working properly with two numeric displays), didn't see the handshake bit go high, then the PVP freezes right up. Needs a power cycle to bring it back to life. Try again, same issue. Go back into the Datalog Properties choose "Use tag names" for the File Headers options and make a new .mer, now everything works just as it should. Go back into the Datalog Properties and then try "Template" under the File Headers options and this time UNCHECK Enable tamper detection, load .mer, everything works.
So, has anyone else experienced this issue? It seems as if you want to use tamper detection for the .csv file that it creates on the PVP, you cannot use a template of your own making for the file headers to do so.
I was looking for this function, so that i doesn´t need to do it in the PLC. If there are an alarm in the alarm list, i want to flash the...
534
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
667
Good morning, I'm new to PLC and HMIs, and I was given the following problem: I need to be able to filter alarms and events that are only related...
391
Hi I am in the process of making an OT lab for training and to test incident response, an i keep hearing NOT to scan network because some...
896
I'm using FactoryTalk ME version 13. I have an alarm banner that is an on top display. Whenever there is an alarm this banner becomes visible to...
901
