CTI 2500 C200 OPC Server.
wamcclintock
Mar 2009
Londonderry
Hi I am trying to find a suitable OPC server for the above plc. I will be using the ethernet port on the processor and not via the sperate 2572 module. Can any one advise. much appreciated....
Have you contacted Kepware? I would guess the OPC suite for Simantic 505's will work, but I would ask before buying.
The 2500's are supposed to be direct replacements for the old 505 line, I would guess it still uses the same communcations scheme.
OPC server CTI 2500
Contact CTI. They have a OPC server (branded)that you can use via CPU ethernett port.
Hi All, Long time since my last visit. I have a problem with my TI/Siemens505/CTI PLC. I need to configure new IO in the existing Profibus IO...
2,120
Hi There, I have a problem with my CTI 2500-C200 CPU; It is anew release with Firmware 6.02 and CPLD 6.02. My CPU is getting a Fatal Error with...
2,887
I'm having trouble programming a PID loop in 505 workshop. Are there any examples out there of how to program this, or how it even works? I got a...
1,495
Can a Siemens TP277 communicate with a CTI2500 CPU via the ethernet port? There are only DP and serial selections for the Simatic 505 in the WinCC...
2,146
I have a challenging one for any CTI gurus out there. We currently have changed our processor over to a CTI 2500 from a siemens 555 trying to...
1,176
