Current Input or Voltage Input
Chuck
Dec 2002
Elpaso Texas
I have a question on current inputs and voltage inputs. I have read that current inputs are less sensitive to electrical noise than voltage inputs.
I believe that current inputs are safer than voltage inputs at low voltage because of electrical noise.
I believe a voltage input can make false contact. Can you provide any insight.
Yep you are right, current inputs are less prone to noise, as it relies on a constant current converted into a voltage any small spikes will have very little effect, it's ohms law.
if you pass 0.5A through a resistor of say 100 ohms the voltage drop will be constant regardless of the supply voltage.
Electrical 'noise' can be considered as a high impedance voltage source.
An instrument current loop is a comparatively low impedance circuit, wheras a voltage loop is a high impedance circuit.
Apply Thevenin's theorem to assess the difference.
Hello My analog sensor outputs 4-20mA only. My analog PLC input sees 0-10V only. How can I make this work? I tested out a different sensor...
1,822
I'm very new to AB PLC's and very cautious when it comes to hooking new stuff up (hoping to avoid blowing up any I/O cards, haha). Anyway, we are...
2,566
Hi, May i know the how to know the minimum voltage to drive a analog input card. I'm connected to 4-20mA channel for 4 wire, supply voltage from...
6,662
Hi All, I am looking for a Signal conditioner that will have current input and voltage output.I know there are a lot of options, but can anyone...
2,874
Got a 1746-FIO4V 2-analog input (0 to 10 vdc) or (4-20 mA) and 2 analog output (0-10vdc) card. How do I let the card know if it's voltage or...
3,147
