Cutler Hammer D-50 backup
The problem may be that you are using wingpc.
wingpc is loaded with bugs and Eaton replaced it with the ELC line.
The DOS version for D-50 works much better and is a clean install. The down side is that you need a DOS machine on which to run it.
PM me with your email and I'll send the exe. program to you using a free FTP file transfer program.
I have a problem getting the software....Is this a license software? if not do you have a copy that I can get from you? My email is [email protected]
Thanks,
TTV
I have both the cable and the software, Actually I have both the DOS software and the windows software. It has been my experience that the windows software is buggy and unstable.
For copies of both software packages email me at dsmcnc@gmail .com and I'll send it to you.
"Cannot load driver" is probably part of the bugs. You will need a PC that uses Win XP at the latest. Vista, Seven and Eight will not allow WinGPC to work nor will a 64 bit machine.
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
235
Hi. We're planning ahead a cut-over (segregating some IOs on a new PLC) on a MCC Advantage Starter DeviceNet Modules which I'm 98% sure they are...
18
2,353
Can a D50PGM10 handheld programmer be used to edit/view/program a D320 PLC?
438
Good afternoon, Looking to purchase one of these RS232 - RS422/485 Adapters ASAP but not having any luck online. Even Radwell has come up empty...
1,020
Hello! I'm searching the manual for the Cutler-Hammer non-reversing starter model W200M1CFC. I've searched Eaton's website, and only found a...
1,171
