Cutler Hammer WPONIDNA DeviceNet
When we bidded (past tense of bid? bided? bid? Sorry, french canadian)
For this meaning the past tense of 'bid' is always just 'bid'.
For the other meaning ('utter' or 'command', perhaps most common now in the phrase 'bid farewell') there is an alternative mostly archaic form 'bade' (pronounced like 'bad').
Hi all.
Existing IOFlex drop with 4 modules installed in it.
I see 2 bytes at the beginning that looks like it's statuses from the rack before the first DI Module mapping starts, and this is what I'm seeing in the PLC:
Local:5:I.Data[0].0 Flex IO Node 1 Module 0 Status
Local:5:I.Data[0].1 Flex IO Node 1 Module 1 Status
Local:5:I.Data[0].2 Flex IO Node 1 Module 2 Status
Local:5:I.Data[0].3 Flex IO Node 1 Module 3 Status
It looks like those 4 bits are the failure status from each module. Then I see the first DI coming in at Local:5:I.Data[0].16.
Any idea what else can / could be pulled from the reminder of that structure (4-5-6-7-8-9-10-11-12-13-14-15)? I don't know if more than 4 modules can be installed in that rack, so I'm assuming it would be statuses for more modules for now.
But basically, what I'm really trying to figure out is to monitor if the communication is good with the rack (1756-ADN) itself, because I won't be receiving a module failure if the rack is not communicating.
There are some "standard" statuses from the slot structure, but I'd like a little more than just that.
Thanks.
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
235
Can a D50PGM10 handheld programmer be used to edit/view/program a D320 PLC?
438
Good afternoon, Looking to purchase one of these RS232 - RS422/485 Adapters ASAP but not having any luck online. Even Radwell has come up empty...
1,020
Hello! I'm searching the manual for the Cutler-Hammer non-reversing starter model W200M1CFC. I've searched Eaton's website, and only found a...
1,171
I have a couple of these d50 plc's and tried testing them. I jumpered the 24v common to the common input line and then the 24v + to the input...
1,764
