Cutler Hammer D100A
plcduck
Nov 2011
norfolk
I am working with a Cutler Hammer D100A, does anybody know the name/type of cable i will need to get online with the PLC?
You will probably have to build one. See this thread. Read the whole thread 1st, then look closely at post #15. There is probably no more than $15 USD worth of parts needed.If you need help or clarification, please ask. I will be glad to assist any way I can.
Link:
http://www.plctalk.net/qanda/showthread.php?t=50546&highlight=d100
Edit:
Search ebay for this " Cutler hammer d100 plc computer direct connection cable" (without the quotes). I found a couple of ready made solutions.
Edit #2:
Post #45 in the same thread above shows how to modify this cable available on ebay. The ebay link also contains a lot of technical data about the cable in its unmodified form.
Link:
http://www.ebay.com/itm/MAX232-RS232-TTL-serial-cable-DB9-shell-Monitor-ECS-embedded-uC-OpenWRT-/290702083401?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D488271313453158568%26pid%3D100033%26prg%3D1011%26rk%3D2%26
Hi every one,i am new to this forum Here's some problems i need your helps. I've recently purchased the 2nd hand Cutler D100A plc and Toshiba...
88
85,368
Hi, I have an old Cutler-Hammer D100A programmable controller. I have removed the EEPROM (D100EE10 Series A2) and used the LCD programmer to...
7,111
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
242
Hi. We're planning ahead a cut-over (segregating some IOs on a new PLC) on a MCC Advantage Starter DeviceNet Modules which I'm 98% sure they are...
18
2,367
Can a D50PGM10 handheld programmer be used to edit/view/program a D320 PLC?
442
