Cutler Hammer Panelmate 3000
Mar 2004
55
I have a Cutler Hammer Panelmate 3000 Power Series Operator Interface but no software. The program is password protected. Is there a backdoor reset? I wish to delete the program and clear the O/I memory.
thanks,
CTG
I'm not sure what you'll accomplish by clearing the mamory without having the software to create a new application.
The PanelMate supports two passwords, called Password A and Password B. Either or both passwords can be applied to specific templates on a screen or to the entire screen. The password is a number between 0 and 65535. There is no backdoor password.
sounds like he's looking to use it on a different application so clearing it out would be OK.
If I recall, there was also a 3rd password which wasn't really a password but the inputs for a keyswitch on the back. If it is locked with that then you can just wire the two sides together and it will be open (not likely)
Thanks everyone, for the info. My company buys and sells surplus electronic equipment and we usually ship the items with a cleared memory. Having a program in memory can be an issue with some customers.
thanks again,
CTG
Hello, I tried to open the attached .PPS file by all methods. It doesn't work. Could someone PLZ send me the panelmate power pro configure...
2,330
i have a pm1700 in start up mode everything passes except for real time clock (the real time clock battery passes) i was wondering what the fault...
2,297
Greetings To All: I have a Cutler Hammer Panelmate 1500 Power Series HMI that has a screen that is *very* dimly lit. If you "cup" your hands...
3,662
i have a cutler hammer panelmate epro hmi that is connected to my AB slc 5/05. the problem i am having is that random buttons from the panelmate...
20
7,579
I am new to PLCS.net so hello to all exsisting members. I am mostly a hardware repair engineer, I am certainly not a programmer, so I hope that...
5,354
