Cutler Hammer
I've only used the D50, and its software is called GPC. I don't know if it is the same for hte D200. You can go to the Cutler Hammer site (now emphasizing the Eaton Electrical name) below and try searching.
http://www.eatonelectrical.com/NASApp/cs/ContentServer?pagename=C-H/CHHome/CHHomeMainPage
If all else fails you should contact your local Cutler Hammer distributor for assistance. This may be an obsolete product - my newest Cutler Hammer catalog doesn't show a D200.
Hi jjkisner,
Try to get in touch with a Toshiba rep. or disty. This PLC is a modular Tosh. EX100. The software was called PDD250. You will need a version 2 or 3 (the first EX-PDD only allowed to program the compact EX20/40).
Laurent
Cutler Hammer D200 or Toshiba EX100
Here are some links to get you started.
Link to Index page
PDD250v2
PDD250v3
EX100 info
You will need a hardware key, (dongle on the parallel port) to fully use the software but download both v2 and v3. That may be enough to do what you need without the dongle.
D100 Cross Reference
Dave,
I believe the D100 is equal to the EX40 Toshiba and the D200 is equal to the EX100. If so, then the software is different and so the hardware key (dongle) may also be different. I don't know this for sure. Look at the bottom of the web page in the link below.
Click Here
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
241
Hi. We're planning ahead a cut-over (segregating some IOs on a new PLC) on a MCC Advantage Starter DeviceNet Modules which I'm 98% sure they are...
18
2,357
Can a D50PGM10 handheld programmer be used to edit/view/program a D320 PLC?
440
Good afternoon, Looking to purchase one of these RS232 - RS422/485 Adapters ASAP but not having any luck online. Even Radwell has come up empty...
1,024
Hello! I'm searching the manual for the Cutler-Hammer non-reversing starter model W200M1CFC. I've searched Eaton's website, and only found a...
1,176
