CX-ConfiguratorFDT: Upload profibus network topology
HJTRBO
Jul 2008
Melbourne
618
Hi all,
Is it possible with cx-configurator to upload the profibus network with the slave address mapping?
I tried but failed with a CJ1W CPU22 and PRM21 master module. I had to rebuild the entire network from scratch. Luckily the original integrator used the automatic address assignment and had the slaves inserted in sequential order otherwise i would have been screwed.
Surely this is not the case? I know with siemens when you upload the hardware config you get the slave address mapping.
Disclaimer: I dont know CX Configurator.
Do you mean to auto-detect what slaves are connected to a DP network without knowing beforehand which ones are there ? I believe that only a diagnostics repeater or similar Profibus analyser can do that.
Or do you mean to upload a configuration, incl setup of profibus slaves, that has previously been downloaded to the Profibus master (the PLC CPU) ? That is at least doable with Siemens S7. I am guessing that if you can do an upload of an Omron CPUs configuration, then the profibus setup will be included.
Yes, that one.
I tried with cx-configurator to "upload" from the profibus master card shown in the netwrok tree but I was given the error message "upload not supported".
I have to also admit that Omron experience is very poor.
Have not played with CX-ConfiguratorFDT but there is an 'upload from device' tab and I would assume this would do the job.
There are some good people in Omron and I am sure one of them could help if you made a phone call. I find their tech support excellent, and free, if you get the right person.
Thanks BobB,
I have talked to Arif and Toby, however they wern't sure, so i thought i'd cover all the bases and post here.
See if you can get hold of Harry - 'the guru'. Or post at mrplc.com and hopefully Jay Anthony will pick it up.
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
88
I HAVE A OLD MESSUNG HMI AND I WANT TO UPLOAD A PROGRAM FILE FROM IT TO A USB PENDRIVE WITHOUT USING PC OR SOFTWARE...WHAT SETTINGS I HAVE TO DO...
83
in our old machine we used beijer cimrex 41 need to take program backup. i tried it with information designer software through ethernet. ip...
84
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
534
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
460
