[CX DESIGNER] I can't TEST via connect to PLC. Why?
proviton
Dec 2011
shah alam
Hello all,
I have the problem. I can't TEST via connect to PLC. Why? Can somebody help me? (CX DESIGNER)
Thanks in advance.
Open your CX-D project.
Open CX-P - set up a PLC.
Go to simulation in CX-P and 'start CX-P to CX-D simulation' and it will work.
Thank you brother bobB for reply.
But, I have the problem regarding on test via PLC (connect to PLC).
Not about cx-simulator.
Brothers,
I really appreciate your help. I still cannot fix the problem.
However, my problem solved after i install it at other laptop. I don't understand why my netbook can't support it although i was 3 times format it and install the cx-one.
I think the problem is maybe at my netbook.
Thanks for your help. I appreciate it. Now i used the different laptop.
Best regards,
proviton.
I have a PLC program for a 1769-L24ER PLC and would like to test it out on a 1756-L73 PLC in the office that is just for testing. The test PLC is...
968
This is a rather silly issue, but it is incredibly frustrating nonetheless. Occasionally, the shortcut buttons for compiling logic will disappear...
4,496
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
238
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
184
