Data from PanelView Plus 1000 and SLC 5/04
abrigo
Apr 2009
santiago
I have a SLC 5/04 connected to a Panelview Plus 1000 throw a DH+ connection. I want to know if it is possible to connect a computer throw the ethernet port to the PV+ to get the same data that the SLC is sending, so I can have a full history log of the events and alarms that the SLC is monitoring.
Thanks!
It would be easiest if you were to connect an 1761-NET-ENI module to the serial port of the SLC, connect the ENI Ethernet port to the computer.
Then you would need some type of OPC server installed onto the computer, a database like SQL Express, and program that can read from the OPC server and write that data to the SQL database. I can't recommend one as we have one developed in house that does that for us so I don't have the experience in others to recomend one. I believe AB sells something...
You would need logic in the PLC to trigger data collection to fit your needs, then you would need some type of front-end on the database to generate the reports/info.
One utility used in the industry a lot is I/Gear (www.igearonline.com). You would need an OPC Server (RSLinx or Kepware) as well, but it will let you easily log any of the SLC data to a database, spreadsheet, text file, etc.
FYI, I am an engineer at I/Gear, but I am more on the integration side.
If I have a PanelView Plus, is it possible to show historical data via historian on it? I have the application all setup in FT Studio Machine...
509
Hello, I have followed the "On_board Audit Demo" sample in FactoryTalk View Studio ME to add the functionality of exporting the Audit, Alarm, and...
1,173
I am stuck on something, and would appreciate if someone might have a suggestion to help me. I need to automatically email CSV log data from...
1,799
Hello everyone. I would like to set up data logging to an SD card so that my data for a couple of trends is stored even when the screen is...
2,365
Newbie so sorry if this question is very general or has been discussed elsewhere already. We have a R/O system installed presently and I am...
2,576
