Database
munir
Mar 2012
Karachi
21
Hi guys,
i am currently working on a project where in m using fatek plc through which i have read the data of 4 energy meters(EL-measure) giving the values of V,I,P etc the problem is i want to manage the database hourly and keep the record can u suggest how come it is possible or is it possible at all or not i have heard dat i can use sql server and all but i would appreciate if its being done on excel or access
Hello,
PeakHMI can read data from the Fatek PLC and write data to Excel, Access and SQL server.
In terms of obtaining and managing data, you may want to consider Kepware's ODBC driver:
http://www.eternity-sales.com/Kepware/ODBC_Client_Driver_OPC_Server.htm
Not knowing what driver you will require for Fatek, you may want to consider the capabilities of the server and what it can do for your application:
http://www.eternity-sales.com/Kepware/kepserverex.htm
If you have any questions, feel free to respond, pm or email through the link in my signature.
Disclosure - ESI is a Kepware distributor.
Hello,
> Not knowing what driver you will require for Fatek...
Fatek supports two protocols, Facon and MODBUS. PeakHMI can use Facon and/or MODBUS.
Looking at the Kepware website, MODBUS would be the only option to access the Fatek PLC.
I’ve been tasked with extracting PLC (logix 5572) realtime data, storing it in a database (anything compatible with our data) and displaying it in...
42
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
148
Hello to Everyone all over the world: I don't want to reinvent the wheel so I am asking others if they have programmed something similar to this...
298
I have an Access database that I need to pull information from and display in a FactoryTalk View ME station. Is there an easy way to do this?
233
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
478
