Dataman to Contrologix
I have checked both of those items, I even moved the logic into the main routine and removed the module from the I/O tree deleted are references and reinstalled with a different name. The results are the same.:mad:
If an OTL instruction works and an OTE instruction does not, then maybe you're not leaving it on long enough when using the OTE instruction. Stick with the OTL instruction and use the acknowledgement signal from the Dataman to trigger the OTU. You could also use a timer to trigger the OTU in case you never get an acknowledgement.
We run about a dozen of the Dataman cameras where I work, and they are all set up like Steve suggested. The trigger acknowledge unlatches the trigger OTL. We don't have timers as a failsafe, but we might soon, now that I thought of it. :rolleyes: The only downside to this setup is if you need to trigger the camera faster than the program and communications will respond to the original trigger request. On the bench with nothing else taxing the system we could maintain a trigger rate of about 75ms consistently. Faster than that and we started missing reads.
Bubba.
:shoot: Hi, I am looking for a little bit of help : I have Cognex DM 280 barcode reader connected through ethernet to CompactLogix 5380 and...
2,448
Has anyone every attempted to run a Dataman Scanner through a 1783-NATR to take a local network to your enterprise network? I have the NAT...
18
3,016
Hey guys, I have an older Cognex Dataman scanner that i have added to a machine. I have established comms over ethernet. I am able to trigger...
1,781
I am planning on working with a cognex scanner 370 series using a beckhoff PLC and Ethernet/IP protocol. My question is does anyone know if the...
1,250
Hello all.. I am presently working with a Cognex Dataman dm8700dx-e (ethernet) scanner and need to make it communicate (read data from) with a AB...
3,246
